AC has a mind of its own HELP!
Old 09-23-2011, 06:59 AM
MORI3L's Avatar
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
So I picked up my 528i yesterday and I've got to say I absolutely loved the ride home in it. Unfortunately half way home my AC started to blow air through the top vents (I had it on blowing air towards me or the front vents) randomly and there was nothing I could do to stop it. I played with all the settings, turned the car off. The air would only blow through the top vents and would continue even if i turned the car off. When I left the car off overnight everything worked fine again...what is going on!?!!?!?! Please help
Note: The battery was recently changed, I remember seeing threads being made about AC problems after battery changes and I'm not sure if the used car dealer changed it properly before giving the car to me.
Old 09-23-2011, 09:55 AM
umichchris's Avatar
My Ride: ///M5 BEAST
Where did you have the battery changed? Give them a call and have them check the service records to see if they " registered" the battery.
Beyond that, go into your idrive settings and check to see how your vent settings are matched up. You may need to adjust them back to ur specific preferences....
Old 09-23-2011, 12:23 PM
MORI3L's Avatar
The dealer who sold me my car changed my battery...not sure where..
And I played around with all my vent settings....Its fine now but I would hate for it to happen again...and on a hot day
Old 09-23-2011, 12:31 PM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Was this a one time thing or it keeps on happening?
Old 09-23-2011, 12:54 PM
pcy
pcy's Avatar
Very likely the vent settings on the iDrive were not right. After OP 'played around with vent settings' (changed), problem is fixed :-)
Unless you play around again, the problem shouldn't happen again.
enjoy the ride.
Old 09-23-2011, 02:05 PM
MORI3L's Avatar
I was driving with the AC and all of the sudden it would divert air to the top vents...nothing that I pressed would change it's behavior...I could only change it from hot or cold and turning off the car did NOT turn the air off.
This is a little creepy..and It happened twice last night...I would hate for it to happen a third.
Old 09-25-2011, 06:21 AM
MORI3L's Avatar
So it happened a few more times over the weekend
Might anyone recommend an indy shop in the West covina or Norwalk area???
Old 09-25-2011, 08:48 AM
sanjsanj's Avatar
My Ride: E60 530d
Do you have climate control ? advanced?
Old 09-25-2011, 09:16 AM
MORI3L's Avatar
Are you referring to the climate control on iDrive?
Old 09-25-2011, 01:14 PM
AchtungE60's Avatar
My Ride: E60 530i
owner's manual Get used to the vent settings.
Quick Reply: AC has a mind of its own HELP!
