AC fan stays on with key taken out and car turned off
My Ride: 2005 BMW 545i / Black Sapphire Metallic / 6spd. manual / Sports package
Guys....My AC fan stays on and keeps blowing even with the key taken out and the car off. It does not stop at all...When I turn on the car and switch the AC 'on', it seems that the air blows stronger and it turns cold. But when it's switched to 'off', the air keeps blowing (not as hard) and the air is not cold. It seems that the air is coming from the foot and windshield area. I've talked to my mechanic and he doesn't know what it could be at this point and my local BMW dealer tells me that they don't have an opening until next Monday. I'm afraid my car's battery will die until then unless I disconnect it (which I don't if that is the best idea).
Have any of you guys encountered this problem or have any ideas to a solution?
Mine does the same thing too, but it will turn off by itself after a few minutes. Not sure why it does that.
That happened on my '06 about a year ago...I was scared that the battery would run out that I immediatly drove to my BMW center. They then pulled my fuse for the final stage thing (sorry im not sure what its exactly called), to make it stop for the time being. They then reprogramed my computer (with an upgraded software version). The problem hasn't returned since...but she told me when I went to pick up my car that the car has a feature that shuts off everything when the car senses the battery is in danger of dying.
-Good Luck
-Good Luck
Thanks for all the help fellas.
I went back to the car about 20min. after I turned it off and the fan was off. Started it up again and all was fine. Like e60lover mentioned above, I thought the battery was going to die and called my local BMW dealer to quickly setup an appointment with my SA. I guess all is good now for the time being...I dread going to the dealer to get stuff done.
Go to the I-Drive Climate, and turn off the Automatic ventilation. I think you have it on, so that you are facing such problem. And by the way, AFAIK, you have to set this off, while the engine is not running and the fob in place.
Omran
Omran
Omran
Omran
No it isn't Auto Ventilation...The Key is out and the fan is blowing very hard...(at least I know it wasnt Auto Vent for me).
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
My Ride: Make: BMW
Model: 525i
Exterior Color: Alpine White
Interior Color: Beige Leather
Trans: Steptronic
Options Include:
205 Automatic Trans - Steptronic 6 spd
423 BMW Floor Mats
ZPP Premium Package
ZSP Sport Package
this problem just happen to me right now, thank god for e60.net, cuz I was getting scared and the first thing I did was come here for the solutions
all I have to do now is wait
all I have to do now is wait ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
This morning I was moving the car out of the garage and noticed that the fan sounded "funny". I immediately knew what was happening. Sure enough, I removed the key and the fan kept running! I let it run for a few minutes, hoping that it would shut off on its own, but I became impatient and went to the fuse diagram. I found a fuse with the fan symbol (40amp - #3 in the glovebox), so I pulled it and the fan shut off. I put it back in about a half hour later and it remained off. I don't know why 2 different dealers told me there wasn't a dedicated fuse. Mayber other components are on the same circuit? At least I know an easy way to stop it if/when it happens again.
In a way I am glad others have had this problem since the dealer didn't indicate that this was a "normal" problem. I think I saw him write in my chart that I am "difficult". (nod to Seinfeld).
