AC evaporator temperature sensor replacement
My Ride: BMW
Hello,
anybody here ever ever replace the Evaporator Temperature sensor? My car is a 2006 525i N52 engine.
How hard is it to get to?
My AC runs cold for about 10 min, then eventually just blows cool or just regular air. Any tips?
I get a 9C62 Evaporator Temperature Sensor error using the Carly BMW iPhone app.
My Ride: BMW
I replaced the evaporator sensor and my issue is still there. AC runs cold for the first 5-10 minutes then gets warm. I even tried to use an AC Pro refrigerant. I put it in but stopped when the PSI reading was at 45psi. I heard the PSI for the N52 AC port is supposed to be around 35psi. I used a separate AC psi gauge rather than the gauge on the AC Pro can. Any suggestions I can try is appreciated.
My Ride: E60 525i
Hi,
Can someone help with the location of the Evaporator Temperature sensor. My aircon is not working had replaced the A/C compressor and it worked for 2 days and after that it blows normal air. Done an inpa scan and found the below error code - 9c5c evaporator temperature sensor. I could trigger the Ac compressor from the INPA and it blows cold air.
#2 in this diagram...(this is a 2006 530xi and you should put in your car's data):
https://www.realoem.com/bmw/enUS/sho...52#64116920430
