AC/CCC Problem. Help!
Hello friends. I have some problems with my E60 530D 218hp 2004year. So first, I make mistake trying to change VIN number of my CCC navigation with OEM ICOM Next A only and WinKFP, forgot about ICOM B for MOST, now my CCC is stuck on BMW logo. After I make this mistake, I try to change VIN of my KLIMA(IHKA) module and everything gone well and was OK. But later in the same day, the AC stop working, the green LAMP is ON but not cooling. The another problem after that is the big engine cooling fan, working all the time, I am not sure this is came from only from VIN change of KLIMA but... I am scared and I don't know what to do. Please for some help.
Man you messed up. The only way to program VIN/update the CCC is by ICOM B. That's not going to be fixed until you get one. You could change the transfer rate to max and it will do fine but it still will take forever to complete. Rule of thumb, if you don't know what you're 100% doing make sure you have that ICOM B hooked up. There's 4 modules that you must use it with. Other than that using a K+ D CAN cable is fine. If you're a pro you can get by with just the cable but I only gamble when it's absolutely necessary.
With your IHKA just factory code it and you should be fine if the process you used to change the VIN was correct. Seems like the compressor is in safe mode. That's not what it's called but it happens from time to time without you knowing it. It should not have happened with a flash though. I'm out of town today but tomorrow evening I can have a look at it if you'd like. |
(Post 1621310)
With your IHKA just factory code it and you should be fine if the process you used to change the VIN was correct. Seems like the compressor is in safe mode. That's not what it's called but it happens from time to time without you knowing it. It should not have happened with a flash though. I'm out of town today but tomorrow evening I can have a look at it if you'd like. https://cimg8.ibsrv.net/gimg/5series...fd9d7e672.jpeg |
You just need to factory code the IHKA then go into INPA to make sure the codes cleared for it. When you turn on the IHKA for the first time after programming it will calibrate so you'll see a/c flashing green
Load profile -> Expertmode -> F1 -> F3 -> choose E60 from the list -> choose any module you want from this list -> now click F6 Back -> select F4 Process ECU -> choose Module -> Select F2 "change job" select SG_CODIEREN and press ok -> Press F3 Execute job and wait for the buttons to become active, when active it's all done. |
(Post 1621313)
Load profile -> Expertmode -> F1 -> F3 -> choose E60 from the list -> choose any module you want from this list -> now click F6 Back -> select F4 Process ECU -> choose Module -> Select F2 "change job" select SG_CODIEREN and press ok -> Press F3 Execute job and wait for the buttons to become active, when active it's all done. https://cimg6.ibsrv.net/gimg/5series...a1b24f6e9.jpeg ed |
Originally Posted by DragoMPower
(Post 1621314)
Okay. I try it and now, no one of buttons are response. Interest is when i turn light or angel eyes on. You can see from picture all orange diagrams start light, when i turn to 0 the light switch then ac orange bulbs turn off. Wtf happen
What steps did you take to program it and why were you doing it. Is that IHKA original to the car
(Post 1621317)
https://cimg2.ibsrv.net/gimg/5series...a4ec5b8905.jpg |
(Post 1621318)
Yes it is, maybe it was changed before and I just try to change vin, so I think the problem is came from Basic functions of ncs becouse i try with different functions from here. Can you tell me the right function for Ihka becouse I can't understand this functions.
https://cimg2.ibsrv.net/gimg/5series...a4ec5b8905.jpg https://cimg5.ibsrv.net/gimg/5series...fde2f2e7e.jpeg |
Do you have TeamViewer. I don't know what steps you're trying to take with showing the basic functions. PM me TeamViewer so I can look at a few things. Do you have an ICOM B
| All times are GMT -8. The time now is 06:29 AM. |
