AC blows water out
Old 07-31-2011, 04:51 PM
healthservices's Avatar
Sorry my car was dead because of a bad fuel pump and i could not even put it on my lift to repair it. i got it together and running but I just got back from a long tiring day at Disneyland. I'll see if I can take a look at it later. if there is still light
Old 07-31-2011, 05:23 PM
tuffluck's Avatar
no worries man. actually i found it! had my girlfriend navigate me from above using a diagram from realoem.com. no blockage inside the drain tube, however the damn thing had sealed itself shut on the driver's and passenger's side. i am not sure what happened. i opened them both and probably 3 cups of water came out immediately...
fyi to anyone that finds this in a search (cause i hate when people never tell you how they resolved a problem in a thread): i did not take a picture (apologies), but you have to remove some of the rubberish shields under the car. this took about 30-45 minutes. they are tricky shields and a big PITA. i never completely removed the one i needed to, just was able to bend it enough to get to where i needed to.
about 60% back from the front of the transmission (on both sides), look against the wall of the chassis near the transmission and there is about a 10 inch black tube. that tube runs parallel with the tranny and is on both sides of the tranny as well. don't have your eyes anywhere nearby as a lot of water comes out when you finally open or unclog them...
we took a test drive and a little water came out, but nothing near the amount that was capable of fertilizing a corn field beforehand.
Vman33
03-14-2022 04:43 AM
HKninja
03-08-2016 09:50 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
FADAGUY
09-18-2015 09:03 AM
militantgrunt
09-10-2015 02:31 PM
Quick Reply: AC blows water out
