5Series.net - Forums
-   -   Abs & traction control warning (https://5series.net/forums/e60-discussion-2/abs-traction-control-warning-97184/)
ta0sum Apr 15, 2010 10:27 PM
I have style 95 7 series rims on my car with 245/30/19 front and 275/40/19 rear... every time i drive a warning pop up saying active steering,abs,dsc is off! I was wondering is it the rims size or tire size the problem, because when i put on my stock style 123 sport on the warning doesn't pop up. HEEEELP! =] And yess i use the search button :thumbsdown:
John@Motorcepts Apr 15, 2010 11:22 PM
i think ur tires are totally wrong!!! 245/30/19 and 275/40/19?? Where did u get those tires??? It should be 245/35/19 and 275/35/19. The rolling diameter u have now is TOTALLY off. I hope you dont have AWD or else it will mess up the T-case.
ta0sum Apr 16, 2010 12:37 AM
Wheewww nope its not awd =] What size should i put on rear? same as front or can i do 275/35
John@Motorcepts Apr 16, 2010 12:42 AM
I had a typo up there.
This is what you need:
Front 245/35/19
Rear 275/30/19
ta0sum Apr 16, 2010 12:56 AM
by any chance i can just change out the rear into 275/30 and leave 245/30 front? because my rear is worn out and the tires on it is oem Sports maxx
