ABS/4x4 all lights on 530xi...5DEC/5E5C/A0B5
one ABS sensor went bad (front LEFT), no signal at all (speed=0 on this wheel). car was going perfect before
after replacement with ebay sensor 5E5C 5DEC A0B5 car think i am moving in reverse !! (wheel speed detection=REVERSE) bad sensor ?? thanks for any details. |
I would maybe check the wiring to the sensor too
update on this. rust went into the reluctor ring, the ring enlarged, it rubbed against the sensor, the sensor eventualy gave up. after replacement with a new sensor, it broke the affected ring, and destructed ebay sensor.
new axle was needed because there was too much rust, a new ring would have fall off so it took -new axle with abs ring on it -new sensor all codes cleared by themselves the car really went completely idiot without ONE sensor. hth |
Yeah, the ABS unit shuts off all traction assist programs if there is a problem with the sensors
Glad you found the cause of it |
