about the m5 wheels
My Ride: 525i 07
i know it is becoming booring questions about the wheels
see guys if i got the m5 wheels out of an orginal m5 without chaning the tires and installed it on e60 525i would if fit properly??? and what do i need to chance the spacers and the shock absorbers right? coz i'm about to buy this rims and cost here about 5k and i wont be able to give it back so i'm afriad to buy them then it wouldnt fit in my car therefore i will sit on the tires and run them with my own legs
My Ride: 08 Porsche 911 c2s, 01 BMW 740il, 05 BMW 525i, 06 Acura TSX navi
see guys if i got the m5 wheels out of an orginal m5 without chaning the tires and installed it on e60 525i would if fit properly??? and what do i need to chance the spacers and the shock absorbers right? coz i'm about to buy this rims and cost here about 5k and i wont be able to give it back so i'm afriad to buy them then it wouldnt fit in my car therefore i will sit on the tires and run them with my own legs ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
The answer is within the forum.
Search is a feature to be used for all.
the answer is NO to your question. u will need to change the tires.
ahlaan o-sahlaan. ke fi?
yes the tires will rub.
so just change the tires & u will be fine.
My Ride: 525i 07
![Talking](https://5series.net/forums/images/icons/icon10.gif)
m5 wheels you say
you will HAVE TO BUY A M5 fender, as the front tyres are wider at the front, however if you change the tyre size from the stock M5 Conti sport, then possibley, but i hav eread it on this forum some were recently
as i had OEM BBS M5 WHEELS ON MY STOCK FENDER (THERE WERE RUBBING OVER BUMBS ON THE FRONT ARCHES ), CHANGED TO THE WIDER M5 FENDER AS I GOT THESE WHEELS.
My Ride: 525i 07
thanks alot e60beemer
so when u changed the fenders there was a difference right and now no rubbing , and in case i wanted the same offset of the stock m5 wheels i must change the fenders otherwise i can keep my orginal fenders but change the offset of the tires right
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
You will need new tire sizes for the 166 to fit the non M5 e60:
245/35/19 Front
285/30/19 Rear
Hope this helps!
Eddie Presley aka Presley348
My Ride: 545i
Engine: N62
Changing fenders is not necessary. What is necessary is changing the tire sizes. I just put OEM 166 M5 Wheels on my 04 545i, much like a lot of other members have done.
Front Tire Size: 245/35/19
Rear Tire Size: 275/30/19
No issues with rubbing whatsoever.
