6-sp Manual Transmission
I think what you are experiencing is a combination of the CDV and the fly-by-wire throttle engagement used by BMW in the E60.
To mitigate the CDV effect, try using the "sport" button. The sport button "mapping" seems to be just enough to avoid the stumbling effect in 1st and 2nd gears. Of course the best solution would be to remove the CDV valve altogether.
As with most things in life, I could be utterly and completely wrong ...
Good luck.
Good luck.
For now, I'll live with it, but I'll definitely make a note for the dealer to check it out at the next scheduled service ... unless it gets worse over time (or more annoying
[/quote]
Oops, sorry. My bad. I thought you had the SMG (as opposed to the traditional 6 speed).
Umm...I'm confused. In other posts, you've mentioned that you had a manual transmission, but if that's the case, then you should know that there is no sport button to be found. If you were talking about a SMG transmission like you mention, then that would also be confusing since those cars do not have a CDV.
My Ride: 525i SE Black Saphire, Black Dakota Leather, 116 type alloys
Did some experimenting on the way to work this morning (rapid on and off the throttle at various speeds in various gears).
I sorry to say (or should that be happy to say) that I have no jerkiness whatsoever. It's as smooth as the preverbial baby's bottom.
I havn't had a good look under the bonnet so I presume the "fly by wire" reference means that we have no direct throttle cable between the accelerator pedal and the engine intake mechanism? So it's all done by computer controlled sensors?
What does CDV mean?
What does CDV mean?
My Ride: 2005 (born 11/04) 525i Touring: jet black, bi-xenons, sports suspension, extended air conditioning.
Retrofits: hinged cubby hole, AUX-input, generic I-Drive video interface (a.k.a. xbox-e60)
Warranty repairs:
software update, door seals replaced, loose aluminium trim fixed.
Repairs:
Self-levelling compressor.
Hi,
I did the same testing today, and didn't find anything but pure smoothness.
My Ride: 2004 530i 6-speed Titanium Silver/Black Interior
Premium Package
Sport Package
Aux input
30 GB video iPod
Cold Weather Package
Xenon
Red rear reflectors
Tint
Clear Bra
I have done this "move" several times and don't recall hearing/feeling a "thunk". Car has always been smooth.
Good luck.
Good luck.
[/quote]
Are you sure the SMG has no CDV? I was led to believe that it did.
What does CDV mean?
What does CDV mean?
Originally Posted by BMW530' post='229034' date='Jan 24 2006, 11:34 PM
What does CDV mean?
CDV means Clutch Delay Valve. Know what it stands for but not exactly what it does but there is some explanation somewhere on this forum from past reading. I know that I had it on my E46s but were only on the 6 cylinder models. The clutch seems to be a lot smoother/lighter than on the 4 cylinders E46s.
Thanks for that - I know we have hydraulic clutches (not cable), but I can't see why the CDV would come into play when you are just on and off the throttle. I can understand that it would help with a smoother change betwen gears, but not when you are fully engaged.
