6 month old and 2 errors
Hi!
I have a 525i LCI born in september 2007 and I have two issues:
* I have a noise that sounds like when your brakepads are finished, steel to steel. But the sound is even when I?m standing still but not when I accelerate, only without acceleration. Can it be an injection thing?
* The other poblem is rattle just when the rpm is 1200, it might be the idrive but I can feel it a little in the steering wheel as well.
Anybody else with these problems?
My Ride: 535d M Sport / Carbon Black Metallic / Aluminium cube / black leather sports seats / Prof. SatNav / Bluetooth.
Your brake disc grinding sound is the run-flat tyres. You can hear them at a constant speed but they are especially loud under braking - try using engine braking i.e. running down through the gears to slow the car down and you will still get the noise. You can't hear it on acceleration as you have unloaded the front tyres so they no longer make the noise.
I had exactly the same problem and I have just changed my tyres from runflat to standard and it is like I driving a different car, both in comfort and noise. Immediately after the change I believed I was driving at 60mph and was actually doing 90mph - the sound was so different. No more front grinding sound...
If your dealer has a 5er with the optional wheels on non-runflat tyres try taking that for a test drive.
I have a 530i new September 2007. The noise "sqeak sqeak"or "cheep cheep" on overrun...meaning foot off the accelerator... is know about by BMW. I have this problem. The noise is the high pressure fuel pump venting to release pressure. It happens on overrun between about 2500-1500 rpm. BMW do not have a solution at present. I suggest you contact your dealer to let you know if they find a solution. However I do not know if your noise is the same as my noise.
As for your rattle, get the dealer to check your car out. It could be an injector out of tolerance.
My Ride: 2008 550i
Originally Posted by RJH&CO' post='617357' date='Jul 6 2008, 09:47 AM
how can you find out if you have run flats on ur car if you did not buy new?
Throw a bunch of nails in the road and drive over them!!
My Ride: 2006 550i - Metallic Mystic Blue, Sport Package, STEPTRONIC Auto Transmission, Leather Interior, Power Front Seats w/Lumbar Support, Xeonon Head Lights (Angel Eyes), Park Distance Control (PDC), 6-CD Changer, Adaptive Head Light, SIRIUS Satellite Radio, Professional Radio, Premium Sound Package 13-Speakers Logic 7, Weather Band Radio, Voice Control (for Bluetooth Telephone Operatoin), 18" Run Flats, Rain-Sensing Wipers, Front/Rear Heated Seats, Flat Tire Monitor (FTM), Moonroof, Fold Down Rear Seats, Hardwired Valentine One
My Ride: 530i - Black on Black - Sport&Premium
Chances are if you don't see anything saying RFT or SST on the tire then they are non-run flat.
Good luck
And Michelin call them ZP for Zero Pressure.
umichchris
12-10-2015 01:00 PM
