5Series.net - Forums
-   -   550i starts off in 2nd gear from stop? (https://5series.net/forums/e60-discussion-2/550i-starts-off-2nd-gear-stop-103330/)
bonsai55555 Aug 28, 2010 05:07 PM
I have a auto 08 550i, I usually drive in D mode but when I want full performance I shift into manual mode but it always start off in 2nd gear "M2", I have to manually shift into 1st gear "M1". Is there anyway I can change so it will go into 1st gear whenever I'm in manual mode from stop???
Krozi Aug 28, 2010 05:09 PM
Sure, if you want the car to start from 1st, all you have to do is pop the shifter into D/S...so basically pop it into manual mode, but don't move the shifter up or down...
sdg1871 Aug 28, 2010 05:25 PM
That is the only way that I know to start in first gear. Damn those concessions to fuel economy.
Rudy Aug 28, 2010 06:46 PM
Do you have the sport automatic (paddles)? If so, you can press the "sport" button below the shifter and I think you'll start off in first gear no matter what mode the shift lever is in...
bonsai55555 Aug 28, 2010 08:00 PM
no sport button or paddles...
Rudy Aug 28, 2010 08:03 PM
Then I guess my best answer for you is to simply put the pedal to the metal and by golly, she'll start out in first for ya! :D :cool:
