545i won’t start after clutch/flywheel replacement
Well, I got the transmission mounted, drive shaft and transmission refilled.
MORE PROBLEMS. Before I pulled the trans my car would run just fine no issues besides the obvious slipping clutch that I repaired. Well now it won’t start.. I put a brand new battery in it (H8) and it’ll turn and turn, but it just won’t turn on. I made sure all connectors were plugged up correctly and everything else was hooked up. On top of that, my clutch pedal won’t build pressure. I’ve tried to bleed it the manual way with no pump and I’ve had literally no progress besides a little trickle of fluid coming out once. I don’t have access to a vacuum pump at the moment, does anyone know where I could possibly rent one? |
