545i SMG Max speed
Hi guys!
Anyone has tried the max speed with his manual/smg 545i ?
The damn long 6th gear (194 MPH) perhaps could limitate the speed ?
I'm interested in speed by GPS .
Thank you!
Thank you!
Originally Posted by Rudy' post='350670' date='Oct 31 2006, 03:59 PM
The SMG gearbox is the same as the old-fashioned manual so it's likely that the top speeds are the same or very similar...
Ehm ... WHICH is the max speed for manual/smg 545i ?
My 545i is still limited @250 kmh ...
Someone has tried to push the gas to the max?
IMHO I doubt it's a limiting factor.
The "quick reckoning" formula including only air resistance gives a max speed of 278 kph / 173 mph for a 328 bhp engine.
Originally Posted by dlevi67' post='350781' date='Oct 31 2006, 08:23 PM
That could be a problem if the engine power at shift point (5th -> 6th) is below the critical level needed to keep the car going. Tricky to work out without a power curve or a torque curve... if you can point me at one, I'll work it out for you.
The 5th reaches 169 MPH, 6th 194 .
Has nobody tried ?
Germans, where are you ?
I've posted this chart in several threads.
Thus my 545i does 194 MPH, sure!
A brain for Cobra, please!
(I already had that schedule)
damn!
so if we have enough road to redline the car then i can hit 194mph and a step can hit 212mph?!?!?!
Originally Posted by jet190rs' post='351209' date='Nov 1 2006, 07:34 PM
damn!
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
i highly doubt these speeds due to air resistance and friction.It will not be that high.For sure
