545i Died Today
Originally Posted by BMWFan' post='324365' date='Aug 19 2006, 02:30 PM
And finally, where is the battery in the E60? In my old E46, SL55, etc the battery has been in the trunk but a quick look and I couldnt find the battery. After a glance I couldnt even spot the battery in the owners manual....where could it be?
- Al
- Al
Battery is in the luggage compartment. Raise the floor mat. Undo the screw of the right side panel. You have now access to the fuses and the battery. (Well, at least for an european 525i, but I haven't seen any exception in the manual).
Edit: Sorry 53r Sport. Didn't see your much better explanation...
Originally Posted by Iceman' post='324355' date='Aug 19 2006, 12:43 PM
Nope.
Yes.
The power is monitored, and when the system recognizes that there is a leak/loss, then all systems will be shut down by the computer to preserve enough power for one more start, so that you can drive away and visit the dealer.
That's one of the reasons the car wakes up from its sleep mode sometimes, to measure everything.
Of course it will die! One thing is that the car tries to preserve energy, and it's true that ALMOST ALL systems will be shut down (legally prescribed systems like hazard warning lights and side lights are never disconnected), but even with this, the battery level can drop and it will not be able to supply enough energy to make the engine start. (Battery can be defective or reached its end of life).
It may even occurs that the car sent a warning measure during the night, but nobody was there to see it...
I received this message some days ago, when I was using a electric inflator connected to the lighter.
Originally Posted by Iceman' post='324355' date='Aug 19 2006, 03:43 AM
QUOTE(rodneyremington @ Aug 19 2006, 06:36 AM)
Eh?
Every battery will die eventually.
Nope.
Eh?
Nope.
My Ride: G30 M550i
Model Year: 2018
Here's a link to an older post that should explain how the car handles electical power issues, etc.
http://forums.e60.net/index.php?s=&sho...st&p=118669
My Ride: F02 LCI Individual
Model Year: 2013
All the systems that will NOT be shut down don't use enough power to drain the battery to a level where you're not able to start the engine, since evereything else will be shut down waaaay earlier.
Originally Posted by Iceman' post='324475' date='Aug 19 2006, 11:33 PM
IF the battery is defective, then YES, but only then.
All the systems that will NOT be shout down don't use enough power to drain the battery to a level where you're not able to start the engine, since evereything else will be shut down waaaay earlier.
Model Year: 2013
Originally Posted by dlevi67' post='324491' date='Aug 20 2006, 01:46 AM
Defective battery is probably the case - I can't understand how someone who drives 200 miles with a presumably functioning alternator can then have a working 80/90 Ah battery drained the morning after!
My Ride: G30 M550i
Model Year: 2018
Model Year: 2013
Those "legally prescribed auxiliary consumers" are switched on by the driver, so he knows about. They don't need much power, what means it takes HOURS to drain the battery to a level an engine start is not possible anymore.
Here is new Service Bulletin related to this issue. May not be the case here, but is relevant.
SI B 61 07 06
General Electrical Systems August 2006
Technical Service
SUBJECT
No Crank, No Start, CAS FC A111
MODEL
E90/E91 (3 Series), E60/E61 (5 Series), E63/E64 (6 Series)
SITUATION
The engine does not crank. Only the SRS (Supplemental Restraint System) and red brake lights show in the instrument cluster with ignition on. FC A111 (ELV voltage supply fault) is stored in the CAS (Car Access System)
CAUSE
Low 15WUP signal voltage caused by faulty IBS (Intelligent Battery Sensor)
CORRECTION
In case of customer complaint, disconnect the IBS connector X13895 (3-pin connector with 2 wires). The IBS is located on the negative battery terminal. Follow the white/blue and gray wires from the IBS to locate X13895.
If the vehicle now starts, the IBS is faulty and must be replaced.
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
Negative battery cable with integrated IBS
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
SI B 61 07 06
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
CORRECTION
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
