545i brakes on 530i
My Ride: BMW E-60 530I
hi guys i wanna upgrade my brakes, well for looks only.
I know m5 brakes are bolt on but the replacement cost is extremely high. Has anyone upgraded their 530i brakes to 545i brakes? i know the front and the rear rotors are bigger compared to 530i
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Yes, can direct bolt on without issue.
My Ride: 530i
You need calipers/carriers/rotors. Others no need. You can also change to Stainless Steel Brake Lines if like. Front and rear in same case.
if you wish, for looks, we carry some aftermarket rotors that are OEM-sized direct replacements that can be custom drilled, slotted, or both drilled and slotted.
My Ride: 530i
Sachal its really not a hard job to tackle, I would say less then 4 hours if you took your time. And cost wise yes they are a lot better compared to M5 setup.
thank you everybody, i will be doing this and making a how to, for others to follow.
13 rotors behind a 19/20 inch rims look tiny!!
