545i 2005 Cam position Sensor Faults
My Ride: 545i Sport
My 2005 545i currently has the following faults. P0365, P0392, P0300, P0306 and P0305.
Engine runs rough at idle and is definitely dropping a couple of cylinders. Previous maintenance, replaced both valve cover gaskets and upper timing covers. Removed and reinstalled intake manifold to facilitate replacing secondary air valve and Y- tube. Replaced Fuel tank vent valve.
First start after repairs codes were as above with addition of P0390 and P0307 and P0308.
Replaced Exhaust cam position sensors, checked connection for all removed wiring.
Any suggestions on the next step?
Prior to repairs had Fault code P0444 and P0491.
Thanks,
Dave
