545 RPM problem
Old 07-15-2010, 01:26 AM
bzq
bzq's Avatar
Originally Posted by w84me
Do these things have PCV valves? Hard to start when hot sounds sort of sounds like a classic PCV valve issue. Search around, they are cheap and generally easy to change. You may even be able to test it by shaking it. You should hear a ball bearing shake around. If it is all oily and you can't hear the ball bearing shake, it probably needs replaced.
I got new ones I dont need to check it I just start to thinking about MAF, could be? Could MAF make problems with engine starts?
Old 07-15-2010, 08:06 AM
w84me's Avatar
My Ride: 2004 545i Sport Pak
If you're referring to Mass Air Flow sensor then beyond my expertise, but I would imagine it could cause all sorts of problems including hard to start, rough idle, reduced performance, reduced gas milage. But I would think you would get a warning if your MAF is having trouble.
Old 07-15-2010, 08:14 AM
v_therussian's Avatar
Why not try to clean the MAF sensor? That's where I'd start. If problem's still there after a good cleaning, start looking at coils, engine management and so forth. But start with the easiest cheapest fixes and work your way up. Worst case, you'll end up with a mini tune up. Speaking of tune ups, how many miles on your car and when was the last time you took it in for one?
Good Luck
Old 07-15-2010, 01:48 PM
w84me's Avatar
Originally Posted by e6t.lab.rat
No our 5ers do not have Positive Crankcase Valves however, we (545,550) do have Pressure Regulating Valve instead. They serve pretty much the same purpose, and mine at the time illuminated the CEL.
Check this DIY I did last year with detailed pics on page 4:
https://5series.net/forums/topic/853...e/page__st__45
Just read your post over there - Great post! How many miles did you car have on it when these needed replaced?
Old 07-16-2010, 05:23 AM
bzq
bzq's Avatar
I replaced it just for fun, so I got new ones and this is not a problem
cinergi
08-03-2018 04:31 PM
E60I
04-30-2015 05:07 PM
navisingh
04-18-2015 02:20 PM
Stranger12
04-05-2015 10:42 AM
Impac
03-29-2015 05:18 PM
Quick Reply: 545 RPM problem
