545 RPM problem
Old 07-12-2010, 09:28 AM
bzq
bzq's Avatar
Hi,
Does anyone had problem with RPM`s on hot engine? When I stay on traffic lights my RPM`s gone crazy, they swimming from 600 to 900. It could be Mass Air Flow Sensor?
Old 07-12-2010, 10:03 AM
e6t.lab.rat's Avatar
Does the CEL (check engine light) illuminate? Any idrive warnings? Check the pressure regulating valve or it could be as simple as a hose coming loose - a vacuum leak somewhere posibly. Good luck
Old 07-12-2010, 10:41 AM
bzq
bzq's Avatar
CEL doesnt illuminate, no infos on idrive. Just when driving up to 2k RPM engine swims over 2 k everyting is ok. When idle also swimming RPMs. I tried To disconnect MAF and engine doesnt want to start. What is Pressure regulatinbg Valve? PCV?
Old 07-12-2010, 12:33 PM
w84me's Avatar
My Ride: 2004 545i Sport Pak
make sure to try the easy stuff first, my RPM's drifted at lights too, when I changed the air filter it smoothed right out.
Old 07-13-2010, 07:44 AM
545 Guy's Avatar
My Ride: 545 2005 Model. Full spec so happy with as is.(for the moment!)
Similar problem for me and my 545. Asked the dealer to fix on my last two visits but no change.
Would be interested in a solution to this niggle.... anyone?
Old 07-13-2010, 07:52 AM
Small Tomato's Avatar
My Ride: '08 530i Luxury LCI
Ignition coil?
Old 07-14-2010, 11:30 AM
bzq
bzq's Avatar
Originally Posted by Small Tomato
Ignition coil?
I have also problems with engine start when is hot (operating temerature). It looks like he start wihout some cylinders ant keep starting unless all cyl starts. Normally it starts fast but last time it needs 3-4 sec more.
Old 07-14-2010, 11:48 AM
bzq
bzq's Avatar
Ignition coil?
it looks this same like mine, what is this?
Old 07-14-2010, 05:03 PM
w84me's Avatar
http://www.youtube.com/watch?v=iIQq9pAlkhg it looks this same like mine, what is this?
Do these things have PCV valves? Hard to start when hot sounds sort of sounds like a classic PCV valve issue. Search around, they are cheap and generally easy to change. You may even be able to test it by shaking it. You should hear a ball bearing shake around. If it is all oily and you can't hear the ball bearing shake, it probably needs replaced.
Old 07-14-2010, 08:27 PM
No our 5ers do not have Positive Crankcase Valves however, we (545,550) do have Pressure Regulating Valve instead. They serve pretty much the same purpose, and mine at the time illuminated the CEL.
Check this DIY I did last year with detailed pics on page 4:
https://5series.net/forums/topic/853...e/page__st__45
Quick Reply: 545 RPM problem
