545 gas mileage
Old 06-30-2005, 11:56 AM
  #61
JDN
JDN's Avatar
The reset for average fuel economy is the bottom button on the end of the turn indicator stalk. It resets average speed, mpg, etc. Hold it in and it will reset.
Old 07-01-2005, 02:40 AM
  #62
grogan545's Avatar
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by JDN' date='Jun 24 2005, 02:12 PM
Not yet. I have your instructions down pat and understand. However, I cannot get my set up to react properly. I apologize for not giving you a final report via PM, but fully intend to pursue the project on another day before I finally throw in the towel. I certainly appreciate your thoughtful and helpful PM.?
[snapback]142784[/snapback]
I just read the post about the thread on bimmerfest.The last 5 digits of my vin
added equal 21 hence 21 is my unlock code.It appears this is how each individual car is unlocked so 21 may not work on your car.Add your last 5 digits and try again.
Old 07-01-2005, 04:41 PM
  #63
JDN
JDN's Avatar
Originally Posted by grogan545' date='Jul 1 2005, 05:40 AM
[quote name='JDN' date='Jun 24 2005, 02:12 PM']Not yet. I have your instructions down pat and understand. However, I cannot get my set up to react properly. I apologize for not giving you a final report via PM, but fully intend to pursue the project on another day before I finally throw in the towel. I certainly appreciate your thoughtful and helpful PM.?
[snapback]144927[/snapback]
[/quote]
Mine add up to 34. So, I dialed to 19 lock on, and started punching to 34 -- nothing so I went on up the scale and started over. Came back and 19.-- lock off was there (repeatable). If I didn't punch anything, it just sat there and went to 19.00. If I punched 19.--, it went to lock on with the codes below again and recycle. Never could get the scrolling zeroes. Did manage to get some screwy set of numbers and some would scroll, but nothing that I could get that would lock on anything like 1040. The screwy numbers were in the 800s and would advance one number per punch until they jumped higher.
Maybe another day. Thanks again for the hints.
Old 07-01-2005, 10:42 PM
  #64
Jeffs's Avatar
My Ride: 2003 X5 3.0----->gone 2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone 2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods... 2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
I like to rev match alot whenever i drive....does this hurt fuel consumption alot??? i seem to get only 19mpg from my 545....is that normal??
Old 07-02-2005, 02:19 AM
  #65
JDN
JDN's Avatar
Mileage depends on driving style and habits. It takes fuel to run the engine, so if the engine is idling or revving, fuel is being used. Downshifting uses more fuel, but hardly a major player in your 19.0 average. My current OBC average since the last refueling is 18.6. OBC dropped from 17.2 to 16.2 yesterday while idling during an hour long creeping traffic delay caused by an overturned garbage truck.
Old 07-02-2005, 03:20 AM
  #66
kryptokat's Avatar
My Ride: 05 545i silver
I have read this topic which has been going on for a while. I have refrained from participating because I was in denial.
I get 14.5 mpg with a avg. seed of 21mph. I do mostly city driving. Now I am starting to think I may have to go to the dealer as I may have a serious problem. I can't even imagine getting 18 mpg. And NO I don't drive with a lead foot. Just normal driving not even using the cars power potential.
2005 545i delivered Oct 2004.
Old 07-02-2005, 06:37 AM
  #67
grogan545's Avatar
[snapback]145192[/snapback]
sounds a little low even for mostly city driving but not extremely low.I typicalyget between 20 & 21 mpg with mixed driving.try going on a highway for about 100 miles,reset your obc before you start.you should get 25 plus mpg
Old 07-02-2005, 02:41 PM
  #68
EBMCS03's Avatar
[snapback]145165[/snapback]
WOW 19!!! I like to see that... ya reving take some gas but not that much... maybe 50cents... total per tank...
P.S. I pulled that number out of my (*you know what*)
Old 07-02-2005, 02:46 PM
  #69
Jeffs's Avatar
hahahahah yeah.....im just bewildered how people get such good gas mileage...i drive conservatively and my commute consists mostly of highways but....i still cant get 20mpg....
Old 07-03-2005, 06:06 AM
  #70
UUronL's Avatar
My Ride: 2006 530i Sport Silver Gray - Black Leather - Anthracite Maple Manual Transmission Premium Audio Cold Weather Package Rear sunshade Sirius Radio Autobahnd Roadblock (3M) film kit
[snapback]145375[/snapback]
After a few fillups with the lower tire pressure, I can say that -not- running the highest load pressures will result in a decrease in fuel economy of up to 5 MPG. I switched mine from 44/36 to 35/29 and I went from about 27MPG to barely over 22MPG. Same driving and routes. I've waited to see it trend over about 3 fillups before reporting. Oh, and with the lower pressures, the computer seems to be spot on with my hand calculations.
Quick Reply: 545 gas mileage
