535xi with p0103 maf high voltage?
My Ride: 2008 535xi
Hello,
I can't find anyone talking about the p0103 code and the n54, I'm assuming it's because the n54 doesn't have a maf
But I have an n54 and a p0103 code.
What should I try? Cleaning the map?
Story:
On the way home, on the highway, I started getting what felt like a miss under load, clutch in and it reved fine. No codes or triangles. Near home, looking for parking, I had the the "engine malfunction reduce power" come up. Parked, turned it off and back on. The engine malfunction came back on after a few seconds and a check engine light(p0103)
Thank you for reading,
Morgan
Story:
Morgan
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Hello,
Story:
Morgan
Story:
Morgan
Engine: 3.0 B58; 3.0 M54
You have the N54B30A engine. The part you have is the Intake Manifold Absolute Pressure Sensor (MAP Sensor) 13-62-7-585-492
Model Year: 2005
Engine: N62
I had forgotten that N54 doesn't use a MAF meter to measure air mass flow, but simply air pressure which inputs to a PID controller (Proportional,Integral,Derivative algorithm) to calculate air mass flow and control the fuel injection. Therefore the air pressure sensor (MAPsensor) is what I should have referred to. It is possibly defective. I think that you know where to find the MAPsensor.
jprovence
May 9, 2009 03:16 PM
nigxdoof
13
Jan 15, 2009 12:07 AM
nigxdoof
Jan 5, 2009 10:58 PM
nigxdoof
Jan 11, 2008 01:51 PM
