535xi Manual Swap Wiring help
My Ride: E61 535xi Manuel FBO
Hi all,
I have started a manual swap on my 535xi e61. I have just installed the manual pedal box and the last step is to wire the clutch switch and reverse lights switch. I have tried using TIS, but i am rather unfamiliar with how the website works. I was wondering if anyone here could help me out a bit.
Thank you all
Thank you all
Looks like i got this pinout, posting here in case anyone ever needs it in the future.
reverse switch:
x12 pin 13 (take resistance from pin 13 top pin 31to verify), other pin to ground (at the LCM)
Clutch switch:
pin 1 ground
pin 2 18 dme control a6000 x60001
pin 3 to pin 3 a149a cas
pin 4 to pin 41 a149a cas
reverse switch:
Clutch switch:
pin 1 ground
TSI (11-11-2020)
flyboy
03-11-2007 05:28 AM
