Sponsored by:
Sponsored by:
535i subframe lowering
Old 01-23-2018, 02:39 AM
My Ride: 535i Sport Package 6 speed manual
Engine: N52
Default 535i subframe lowering
I've got a 2008 535i sport that ingested the serpentine belt through the front crank seal, so I'm trying to remove the oil pan to clean out the pieces. I need to lower the subframe and I can't get to the passenger side engine mount bolts. Do you have to remove the exhaust down pipes to get to them? Also, there are two fluid lines that pass through the subframe. Do they need to be removed?
Ken
2008 535i
Sport Package
6 speed manual
rkvarner43 is offline
Old 03-09-2018, 01:44 PM
My Ride: 535i
Default Any Update on subframe lowering
I have the same car, need to lower subframe to replace turbo cooling lines. Any information on your journey would be appreciated.
zingtaw is offline
Old 03-10-2018, 04:31 AM
Engine: N52
I'll try to describe what I did.
1. Raise car and put on jack stands.
2. Remove front wheels
3. Remove engine cover
4. Install engine lift ring (same as tow ring) and engine support (I used the Harbor Freight version) to support engine (apply some pressure to lift the engine slightly)
5. Remove belly pans
6. Remove subframe stiffener plate
7. Remove steering column to steering rack pinch bolt and pull off steering rack
8. Disconnect electrical connector from steering rack
9. Siphon out power steering fluid from the power steering reservoir
10. Remove wheel well covers from around steering rack arms
11. Disconnect 4 hydraulic lines in passenger wheel well just behind the wheel (two shown in the photo) Note- these go to the active stabilization and power steering. If you don't have the sport package with active stabilization, then it may be different.
12. Disconnect the hydraulic quick disconnect at the lower passenger side of the radiator. Remove the white clip and slide the QD sleeve away from the radiator to release.
13. Remove the top nut from the drivers side engine mount.
14. Disconnect the vacuum accumulators mounting bolts to gain access to the passenger side top engine mount nut. Use long extension and universal joint to reach the nut (may have to bend back the heat shield. Once you have the nut loosened, you can reach it by hand from underneath to remove it by hand.
15. Disconnect the end links from the active stabilization roll bar (this step may not be necessary)
17. Remove the link on the height sensor on the passenger wheel side
18. Place a floor jack underneath the subframe. I used a 2x6 to span across the subframe just behind the jack pad point.
19. Remove the 6 subframe bolts
20. Slowly lower the subframe. The subframe and engine mounts will lower away from the car and engine and remain connected to the lower and upper suspension components. Hard to really see, but here's a picture of the subframe lowered.
Note that the subframe and stiffener bolts are torque to yield and BMW calls for them to be replaced. I put in new subframe bolts, but reused the stiffener bolts.
I also replaced my engine mounts since I'm at 110K miles. Both were slightly collapsed when compared to a new one.
Ken
2008 535i Sport w/6 speed
Old 05-13-2019, 12:56 AM
My Ride: 2008 535i Sport Automatic
I was doing this today for the same reason.Your post proved to be invaluable to me since I couldn't piece it together on my own with just whatever is available in TIS.
Many thanks to you, sir for taking time posting this!
One thing I wanted to add, for automatic transmission you *absolutely* have to disconnect a mounting bracket which fastens trans cooling lines to the subframe. Yes, subframe, not oil pan. Bracket is located on the driver's side and is pretty much hidden unless you know what you're looking for. Here's a link to TIS online. It's a second to the last diagram: https://www.newtis.info/tisv2/a/en/e...l-sump/4NuSJRf
Whoever worked on my car before my time didn't release that bracket when lowering subframe and that costed me a transmission since it ended up running low on fluid due to a slow leak thru that crack.
Cheers!
dpersh is offline
Old 05-13-2019, 01:30 PM
Engine: N52
Cheers!
Glad it was of some help. Found lots of information on the 335i, but not as much for the 5 series. Love the forums and how much info is out there!
Old 05-15-2019, 11:25 AM
My Ride: 2x E61, 1x E60, 1x E90
Model Year: 07,07,10
Engine: N52, N54
VERY IMPORTANT: Make sure you mark the position. My bolt would not go out and I had to remove the spline part of the steering column. Even if you take the bolt out make sure to disassemble and re-assemble the steering connection with a straight steering wheel. Trust me this will save you an extra lowering of the sub-frame, don't ask me how I learned.
dcfjord is offline
timmay77
02-26-2016 10:41 AM
Quarta2six
01-02-2015 06:20 PM
jordon
05-09-2014 06:19 AM
boosted5
02-22-2014 07:25 AM
liquidape
03-30-2011 09:30 AM
Quick Reply: 535i subframe lowering
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
