535i Rough Idle On Warm Startup Only ??
My Ride: 2008 BMW 535i Sport
![Cool](https://5series.net/forums/images/icons/icon6.gif)
I have a 2008 535i with 37k miles seems to run excellent starts perfectly on cold start up but once its warm it will have a rough idle on startup for about 5 seconds then go away . I appreciate the help if your familiar with this problem. Thanks, Frank535i
no error codes. nothing seems to be wrong besides a shake for a few seconds on a warm start . any ideas or nothing to worry about ?
My Ride: 2010 535 IX
Hi Frank I have a 2010 535 I and I get the same thing and I have about 85,000 and no one seems to be concerned about it I get no error messages if you've solved yours I would appreciate an answer.
Lester in Connecticut
My Ride: 535i 6-speed
My '08 535i has an odd behavior...from a cold start...nice, easy crank, start, running. Exactly 60 seconds after the car is cranked & running...I can hear/feel something in the engine change...sorta quiets a bit, smooths out a bit. And...if I drive away BEFORE this 60 seconds...the car kinda skips (very slightly, sometimes not at all even)...acts like cars used to when they were "cold". But if I wait until AFTER the 60 seconds...the car runs perfectly. I wonder what happens at exactly 60 seconds after the car starts running?
I was going to say the same as E60dad with walnut blasting. Also, sparks plugs, and coils can cause this along with injectors. Plugs would be your cheapest task, but if you ever throw a code this would help to determine the cause, otherwise you could just be throwing money at it.
