535i- long crank & misfire
My Ride: 08' 535i
Hey guys, so last night I went to take my car to meet some friends, going down the highway, I had my cruise set at 65, and all of a sudden it misfires and felt like I hit something, my cruise disengaged, and I have a engine malfunction display on Idrive. I pull over, shut it off, restart it, the engine malfunction is still there. I let it sit a little longer, start it again and it's fine. I drive it home, it's running fine, take it for like a 40 minute ride that night and it's fine. This morning I'm leaving for work, starts fine, I make it halfway down my driveway, and it misfires again, with the engine malfunction message and this time a hard engine light on the dashboard. I shut it off and try to restart it and now it's cranking for a noticeably long time, but does start, it idles kinda rough but not awful, still has the engine malfunction and dashboard light. I just had the hpfp replaced at 144k and I'm at 152k now. (Also all my injectors were done around 140k). To me it sounds like the new hpfp failed, but I'm just wanting other opinions before I call the shop this morning, thanks!
My Ride: 08' 535i
I don't have a scan tool for a BMW (i need to invest). I drove it a half hour to the shop. It had no power but ran smooth for the most part? Still has the lights apon start up. The shop said it's probably nothing big, seeing my injectors and hpfp are new and I have newer spark plugs and coil packs (previous owner had them done before I bought it just over a year ago). Hopefully I'll here back about it today.
My Ride: 08' 535i
Had the same exact problem a few months ago and my mileage is 147,000. I had the long crank and the check engine light would not stay off no matter how many times I reset it, the car also suddenly turned off twice while at a light and would misfire constantly when I try to accelerate . My codes said it was the exhaust camshaft sensor but I changed both exhaust and intake sensors and that solved the long crank, check engine light and limp mode. As for the misfire, it was spark plugs, but your problem is most likely the camshaft sensors. Hope this helps.
Techno79
11-21-2016 01:53 AM
