535d Running Fault any ideas
Hi guys I recently bought my 2005 535d and have a problem where it is held flat out say 130mph up it will sometimes cut the power be very flat and not change up a gear and just rev ?
It will work in manual box but the car is not full power still. Then I switch the engine off and back on and its all fine again any ideas ?
Thanks
Stu
Thanks
Stu
Thanks
Stu
Thanks
Stu
Originally Posted by slk55stu' post='800187' date='Feb 24 2009, 10:16 AM
How about Cam Sensor or MAF ?? What you think are these common problems ?
Hi Guys
Got this fault code come up anyone have any ideas ?
428b Charge Air Pressure to high negative control device large turbo
Sounds like your bypass valve is sticking shut or partially closed. I have a diagram of how the turbos work I will see if I can post it you will see what I mean
dynodave
04-20-2015 12:23 AM
