535d losing power
Hi all
I recently had a brand new engine, turbos and exhaust system fitted all proffessionally done by williams Bmw, due to flood damage to the engine causing the engine to hydraulic.
The car now runs sweet 6 days a week but what seems to be at least once a week the engine looses power when putting my foot down i have to put the pedal down at least halfway before the power will kick in sometimes throwing me back in the seat, there seems to be a huge turbo lag ???
Ive had it back into them twice but low and behold the days its booked in its running fine and dandy, the service guy told me to take it in next time it does it as there are no faults reported, but again as luck would have it it seems to play up over the weekend.
It will be like this for half a day, a day and sometimes a day and a half then it will just go back to normal for another week or so, Ive also noticed that when its doing this i can smell a burning smell, a bit like a burnt out clutch and the underside of the car clicks as if red hot ???
Any ideas Please !!!!
Originally Posted by steant' post='674628' date='Sep 21 2008, 07:47 PM
Hi all
My Ride: April 2007 520D M Sport LCI. Automatic. Sunroof. BMW Bluetooth. Deep Sea Blue Metallic, Natural Brown Leather.
Hi all
Originally Posted by artc' post='675135' date='Sep 22 2008, 05:19 AM
Could be the Particluate Filter in the exhaust going through a 'burn' cycle?? How many miles are you covering between these incidents?
I first thought it may be a turbo problem because of the lag until one night when it was doing it i walked around the back of the car and could feel the heat just standing behind it which seemed to be coming from the exhaust this lead me to believe it was more of an exhaust problem, i also get a much stronger smell of burning from the back of the car and it seems the whole exhaust system is boiling hot causing it to click.
Is this burn cycle normal ? and could it cause the car to lose power ?
Originally Posted by steant' post='675719' date='Sep 22 2008, 11:23 PM
Once a week so maybe about 300-400 miles,
I have covered ~ 55,000K in my 520D and only noticed this happening a couple of times.
Hi, have you had the car back into the dealers so they can put it back on diagnostics. The fault does not have to be there as the dis system will hold many faults until cleared by their computer. So i would get it back into them. If it is a sensor or module or wiring then it will store the fault.
cheers
cheers
jashy247
Feb 23, 2021 05:50 PM
