535 oil change
Old Aug 11, 2009 | 06:14 PM
vwvwvw's Avatar
All the threads on oil change intervals have made me paranoid enough to change the oil myself at around 9800 miles.
But does anyone know whether you need to prime the oil filter housing with oil, or should you just put the filter in there dry and let the system fill up on its own?
Old Aug 11, 2009 | 06:15 PM
Gene's Avatar
have you read thru member MiamiPhill's DIY for a 535i oil change
https://5series.net/forums/index.php...opic=49786&hl=
Old Aug 11, 2009 | 06:29 PM
MiamiPhill's Avatar
I don't think it makes a huge difference but if you want to, it won't hurt. I wouldn't put more than 1/3 of oil in the housing & not in the cap.....would just be a mess.
Old Aug 11, 2009 | 06:33 PM
vwvwvw's Avatar
Originally Posted by MiamiPhill' post='972996' date='Aug 11 2009, 07:29 PM
I don't think it makes a huge difference but if you want to, it won't hurt. I wouldn't put more than 1/3 of oil in the housing & non in the cap.....would just be a mess.
Cool, thanks. So when you start the car for first time after the oil change, does the pressure light come on for a few seconds? Any warnings in the Idrive?
Old Aug 11, 2009 | 06:50 PM
MiamiPhill's Avatar
No not at all, what you do hear are the lifters....they clatter for 3-5sec. then go quite as the oil reaches them, but this happens to most cars after an oil change or if they sit for extended periods.
Old Aug 11, 2009 | 11:19 PM
vwvwvw's Avatar
Ok thanks. I'll give this a whirl on Saturday.
coolspot
May 7, 2015 05:50 AM
demosthenesish
May 1, 2015 06:02 AM
Boland01
Apr 6, 2015 10:25 PM
ajs916
Apr 5, 2015 01:24 PM
mantraguy
Mar 9, 2015 02:56 AM
