535 biturbo vs 550
#41
Originally Posted by BetterMakeWay' post='315747' date='Jul 27 2006, 09:10 AM
Ya it is as i said if we think of screaming engines, buuuut a tweaked turbo petrol engine sounds sometimes so intoxicating, put an insane bov and it's complete. Wooooshhh!! ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
#43
My Ride: Look At My Signature. -Other Rides and Previous Rides: 04 BMW X3 | 03 BMW 330i (Sold) | 05 BMW M3 (Gone)-
05 Infiniti G35 sedan, Premium Package, Bose Sound, HID, Sports Package, Hardwired Escort Passport x50 Blue Installed, New Transmission Installed, Navigation, Keyless Entry+Start
Other Current Ride.
535 is diesel right
#44
Has BMW actually said anything about fitting the petrol bi-turbo into the E60? Or is it speculation? I'm more interested in whether or when they'll fit the NA Direct Injection 3.0 into the 530i.
#45
BMW also needs to get motivated and bring a diesel to the U.S. MB has been doing it for years and the demand is there!
#46
Originally Posted by EBMCS03' post='315546' date='Jul 26 2006, 09:55 PM
Costs of a V8, gas comsumption... etc etc. its the 535 will probably replace the 530. The market will not want that many V8s majority of the buyers will look at the number of cylindars and go OMG V8 gas guzzler and just blow it off. I6 V6 even H6 ok maybe not H6 but 6 cylindars are more appealing to 75% or more of the population.
#47
Originally Posted by bmw4life' post='316138' date='Jul 28 2006, 08:41 AM
535 is diesel right
#48
Originally Posted by Bimmer32' post='316089' date='Jul 28 2006, 07:33 AM
So you do like turbo over NA? I think turbos and superchargers is added components to a regular engine, but I think technology is working its way into making these "boosters" as part of the engine. So eventually, you no longer have these external "boosters," they will be part of the engine technology itself. Right now, they are extra components and therefore, may tend to break down as parts "not part of the engine."
#49
A turboed engine gets more benefit from chipping by turning up the boost. I had a 300TT prior to the 545 and by chipping you went from 300 to 400 hp (with required intake and exhaust that did fairly little by themselves). Boost went from 9 psi to 14.5 psi. The manufacturer will usually keep the boost on the low side because of reliability concerns. Boost could be turned up more but the fuel injectors had a limited amount of flow so you would get a lean condition. The turbos were efficient up until about 17 psi - but getting there required the bigger injectors which costs some $$$. The drivability was affected somewhat because the boost hit you harder. They design a flatter torque curve and you make it a bit steeper. It takes more time to get to maximum boost so the cars rate of acceleration increases more. It was not unusual to loose traction as you hit full boost (along with more rpms) around 4000 rpm in second gear. Not exactly balanced - but a lot of fun.
Now - once a car has a turbo - you can change it out. This is where crazy numbers come from but the new turbos typically lag more because they are bigger and you will lose some drivability. But the sky does become the limit. That Nissan block could handle about 600 hp and people did it (probably still do) but you have to change a lot of parts at that point.
bestofthebest
01-05-2016 07:47 PM
Lotus99
11-26-2015 11:07 AM
PelicanParts.com
Meet & Greet Discussion
10-16-2015 03:07 PM
E61mendo
09-15-2015 03:55 AM
