530xi won't start
My Ride: 2006 530xi wagon
Update, I got the new alternator and, as expected, it still did not start. I took the manifold off yesterday and bench tested the starter and indeed it was bad. Strange coincidences. When taking the manifold off I followed a nice set of instruction from BMW repair guide. However, they do not remove the throttle body to unscrew the wiring harness, but instead take it off the manifold after the manifold is unbolted. This proved to be a mistake for me, since moving the manifold to reach the wire harness bolts resulted in me breaking the crankshaft position sensor connector. I think I found a repair kit, but it will be a pain to repair. Please let me know if you have any hints on how best to fix the [size=13px]connector.[/size]
OK, finished replacing the starter and that was definitely the problem. The car starts easier and stronger than it ever did. Since I broke the crankshaft position sensor connector when taking the manifold off, I replaced the connector and sensor. Prior to the fix, the transmission shifts from 1st to 2nd and maybe 2nd to 3rd were not smooth. The repairs fixed that and the transmission shifts like it was new. Also, replacing the CCV and inner (lower) disa valve seem to have smoothed out the idle a bit. Still not perfect but definitely better and the car is a bit sprightlier off the line. So all around a big improvements. Now just waiting for the vacuum leak to arise due to strong arming the CCV hose leading to the valve cover into place .....
twh (03-13-2024)
Administrator
My Ride: 530xi
Engine: N52
How many hours labor can I expect to pay a master BMW mechanic (not the dealer) to replace my starter? I think mine is starting to go. I have an indy that I use and he last quoted me $800 to do the job.
JayArras (05-16-2024)
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
