530d Windscreen Wiper Problem
My Ride: bmw 5 series 520d 2007
hi I have the same issue 10 sweeps then my wipers shut off no matter what setting iv had relay changed still the same they only work after 5-10 min or buy turning off the ignition and turning it back on any ideas guys
Probation Members
My Ride: 2010 BMW 535I E60
Hi, lifting this old thread. Now I got the same problem....
When I turn on the wipers they make 10 sweeps and then stop in wrong position. I can restart the wipers and they do the same thing but stops in next wrong position. Then they are dead for 3-4 minutes and after that the same procedure can be done again. Washer is also not working. When stop and restart the car the procedure also can be repeated.
I had the car to BMW dealer and they said the motor and wiper arms must be replaced. >700 Euro!!
That doesn't seem logical as the motor works? In my mind it seems lika a relay or data box failure?
Anyone solved the problem?
My Ride: e60 pre lci 530d M-sport carbon black
I'm having the same problem to. I have changed relay twice 2nd relay was a new one and put a new motor on (not linkage). Still does the same thing I have ordered a new wiper arm the one that sits closer to the middle as it's got the bearings in. Gona fit that tomorrow.
Its nice to see that people update there threads when they fix their problems so others have a guide to follow.
I shall update if if it works or not
