5Series.net - Forums
-   -   530d v535d (https://5series.net/forums/e60-discussion-2/530d-v535d-5704/)
the-man-himself Dec 23, 2004 06:48 AM
there is supposed to be a modified front bumper on the 535d se ccompared to the 530d se does anuone know the difference thanks
E60525d Dec 23, 2004 06:55 AM
I dont think it has a different bumper.
JBOO Dec 23, 2004 09:42 AM
I believe there is a differnce in the lower front air vents, but I would have to see them sid-by-side to notice.
Apparently the 535d needs more airflow, not to mention bigger brakes.
Wonder why?
Wonder if all those tuned 530d's need the same since they are boosted up to the same if not more HP?
paasan Dec 23, 2004 09:47 AM
If you were to get the boosted 530ds approved here in Norway, you'd likely have to get the brakes improved too. But.. then again.. nobody ever get their chipped/turboed/supercharged cars approved, as it would cost a fortune in most cases ;)
BangleBox_530d Dec 23, 2004 11:11 AM
Same car are the 545. Why would the 535d need to be different when the intake is the same on the 530d and 545.
Obviously the 545, with bigger engine volume and higher revving, will need more air than a 535d.
BMW535d Dec 23, 2004 11:28 AM
[snapback]71915[/snapback]
I think a turbo engine requires more forced air than a NA engine...
JBOO Dec 23, 2004 11:45 AM
"In standard trim the BMW 535d conveys the power of the engine to the rear drive wheels via six-speed automatic transmission with Steptronic. Just some of the signs of distinction setting the new top-of-the-range diesel apart from the BMW 530d are 17-inch wheels with 225/50 R 17 tyres fitted as standard, a modified front air dam, as well as larger, round exhaust tailpipes like on the BMW 545i."
Source Guideauto.com
paasan Dec 23, 2004 11:58 AM
530d and 535d are both turbocharged, but the 535d has two turbos.. guess that might explain why there is a different need of air supply?
mdoorman Dec 23, 2004 01:28 PM
Originally Posted by the-man-himself' date='Dec 23 2004, 04:48 PM
there is supposed to be a modified front bumper on the 535d se ccompared to the 530d se? does anuone know the difference thanks
[snapback]71847[/snapback]
In Holland it is the same as the 545.
E60525d Dec 23, 2004 01:30 PM
Anyone got pics of the modified front air dam?
