530d Low boost or power below 2000k revs
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys i get very low boost or power on my 530d its a 2003 model E60 currently the Egr valve has been left disconnected for over a year not sure if the Egr has any effect on the boost the car doesnt show up a engine management light on the speedo but does throw up a error on inpa related to exhaust gas recirculation error
so far the engine has been rebuilt due to swirl flaps fault in 2011
it has had 2 new thermostats
new water pump
removed swirl flaps
new vibration damper pulley
new oil breather
new silicone vacuum pipes on all vacuum lines
egr valve was clean and is still clean
cleaned air mass in the pass and boost sensor on the inlet manifold
engine heats to right temp
just the boost problem under 2k seams kinda dead notice this more up hill
any ideas
also i hear the gearbox more when going up hill and slams into first even after gearbox adaption reset
had a gearbox service done last year with fresh zf oil and sump filter
also as my car is a 2003 it didnt come with a dpf from factory
this low boost cant be because the swirl flaps have been removed
any one else have similar issues thanks
new water pump
removed swirl flaps
new oil breather
any ideas
I have a feeling the torque converter clutch is slipping
As revs bounce up and down
chadillac2000
42
09-13-2017 11:15 AM
