530D Intermittent Turbo Problem
Old 02-13-2010 | 04:40 AM
shaunf1703's Avatar
Hi,
I own a 54 (2004) 530D Sport. It has around 60k on the clock with full BMW service history and has started to develop a problem with the turbo.
The turbo sometimes comes on and sometimes doesn't. I can sometimes drive the car with no problems and other times i will try to accelerate and the turbo will not come on.
There is no smoke and nothing showing up in iDrive. I dont think the turbo is damaged as it can works prefectly and then suddently stops working ...and can come back on later in the journey.
Any ideas what could be causing this or anything i can check myself before sending it to the garage.
Thanks for your help,
Shaun
(UK)
Old 02-13-2010 | 08:04 AM
Sanj's Avatar
Hiya Shawn,do you have a dpf(diesel particulate filter)as I know mine seem's sluggish when it's going through the regeneration sequence,you really need to get it hooked up to a computer and see if there are any error code's,i'm sure if it was anything bad it would have shown up in the idrive.
Old 02-13-2010 | 12:04 PM
JasonH's Avatar
On the 535d the vacuum hoses that control the turbos fail after a few years and cause symptoms like this. Not quite sure of the 530d setup but I suspect you'll have the turbo actuator controlled by vacuum hoses so I'd be checking none of these have broken.
Old 02-17-2010 | 01:12 AM
530i-M's Avatar
Agree, vacuum hoses failing or popping off can cause all sorts of drivability issues with turbocharged engines.
That'd be the first thing I'd check
Old 02-17-2010 | 07:34 AM
Mambo's Avatar
My Ride: 535d Sport Carbon Black, Black Dakota leather, Media Package, Bluetooth, Bi-xenon headlamps, adaptive headlamps, auto dimming interior mirror, heated folding door mirrors, electric front seats with drivers memory, heated front seats, extended light package, sun protection glass, electrically adjustable steering column, automatic air conditioning.
Agree with the suggestions above - I had a similar problem recently (lack of power on full throttle as if the turbo was not spooling up) and changing the vac hoses (all of them) seemed to fix it.
Cost me less that £150 from an independent BMW specialist.
Old 02-17-2010 | 11:44 AM
akhtar's Avatar
My Ride: bmw 530d bmw x5 3.0d bmw 320i opel corsa opc bmw 135i dct
hate when this s*** happens with our cabs <>
IRFOMAESTRO
F10 Discussion
02-03-2019 12:22 AM
Stranger12
Lounge
05-21-2015 01:47 PM
Mikethepanel
04-25-2015 03:33 AM
Quojo
04-01-2015 05:00 PM
dexteryout
03-23-2015 02:24 PM
