530d heated seat module
So I have recently purchased a 530d have gone to turn on the heated seats the lights flash and go out I got another seat to try and it’s still doing the same pluged it in and getting fault codes of 93cd no lin communication with heat seating have tried finding a module but can’t find one any ideas it’s also showing same fault for passenger side or were the location for the module is if it has one it’s 2007
Engine: 3.0 B58; 3.0 M54
You'd have to be more specific with the car you have. There's 2 different diagrams. One with and one without gateway. Do you have an E60 or E65
LIN connection goes from center switch cluster (pin 3 to pin 1) then gateway (pin 15) to driverside heating module (pin 3). Location on driver side under seat just past the front cover. Kind of hard to explain
