530d fluctuating revs when held at 1200rpm
When idling, all is fine
I've noticed when I squeeze the gas pedal gentle, picking up the revs to 1200rpm, the revs then start to fluctuate rhythmically between 1100rpm and 1200rpm, about once every couple of seconds. If I squeeze the pedal a bit more (say up to 1400rpm), the problem disappears.
At all other engine speeds, the RPMs are rock steady.
Anyone experienced that?
Please don't tell me I need a new engine
Please don't tell me I need a new engine![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
If anything you'll need a new gearbox...
Originally Posted by colejl' post='392536' date='Feb 17 2007, 09:07 AM
This problem has been reduced by newer software. The 'hunting' problem is connected with the autobox and the torque convertor I believe. It usually happens when going up a small incline?
If anything you'll need a new gearbox...![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
My Ride: 09 E90 M3
I get this on my 530i also. Stick it in Neutral, hold the throttle down VERY lightly and try to keep it at ~1000 rpm - it will fluctuate up and down. I believe it has something to do with the electronic throttle/drive-by-wire system. Happened on my previous E46 also.
My Ride: On Order as of May 6- 2007 530i Titanium Grey and Grey Leather, with Sport Package, Premium Pkg, Cold Pkg.
2006 Porsche Boxster
Why are you revving up to that speed?
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
Just wondering if it was the early symptoms of a more general erratic idling problem
Originally Posted by marklp' post='392538' date='Feb 17 2007, 02:15 PM
No it happens when parked and the 'box is in Park/Neutral. On the move everything seems as normal.
Originally Posted by marklp' post='392634' date='Feb 17 2007, 02:51 PM
No reason really - I was sat in traffic one day and I was squeezing the throttle for no reason whatsoever
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
