525i Engine/coolant temp low and little to no heat
Old 05-18-2015, 05:38 AM
  #101
Pistratoaie's Avatar
My Ride: E60 525i-M Sports 05'
Model Year: 2005
Here's a chart of what mine is doing at the moment on a 240Km trip (2hrs and 20mins) Didn't hit 80 until an hour into the drive. The first hour of the trip was on cruise at 110Km/hr. the rest was in the city and freeway.
Next time I'll also log speed.
Old 05-19-2015, 09:52 PM
  #102
Don dario's Avatar
My Ride: BMW E60 530I
Hi
Ok yes thats a long time! try to unplug the thermostat!
What are yeor info on yor car? model, year , engine and so on:-)
Best Regards
Old 05-19-2015, 09:53 PM
  #103
Don dario's Avatar
Originally Posted by RakDDD
This morning outside temp 8C.. and after 10km (~80km/h) driving engine temp ~80C. After 15 over 90C. (This when part 12 hose plugged).
5 days ago outside temp 6C and none of hoses were plugged. Max engine temp, what I could reach was 78C.
My problem with with engine temp seems to be solved.. problem were part 12 hose (RealOEM.com - Online BMW Parts Catalog)
Hi
May i ask of yor info on your car? to see if there a pattern!
Mode, year, engine and so on!
Best Regards
Old 05-19-2015, 10:51 PM
  #104
RakDDD's Avatar
My Ride: E61 525i 2005
Originally Posted by Don dario
Hi
Best Regards
BMW E61, year model 2005 (5/2005), Engine N52B25. Automatic transmission.
This morning 10min to 80C. Outside temp 9C.
Old 05-20-2015, 01:19 AM
  #105
Don dario's Avatar
Hi
Ahh ok! mine take 20 min. to reach the same 80c?
Are you car still getting the right temp. with hose 12 blocked?
There are software differences depend on what country you live in so i think thats why some has DME issues and like you mechanicly issues.
Best Regards
Old 05-20-2015, 01:26 AM
  #106
RakDDD's Avatar
[QUOTE=Don dario;1563312]Hi
Yes... hose still plugged and will be plugged. DME seems to be working correctly also... when I do "kickdown", DME drops engine temp to ~80C temporary. (Better acceleration with lower engine temp).
Old 05-20-2015, 02:13 AM
  #107
Don dario's Avatar
[QUOTE=RakDDD;1563313]
Hi
HI
Ok how do you block it? with a brakehose Tool like me or?
Thats is very nice it Works for you:-)
Best Regards
Old 05-23-2015, 09:51 AM
  #108
kobolt60's Avatar
My Ride: BMW E61 525i touring MT
Pistratoaie, what kind of equipment and software did you use to map and present in the diagram?
I also wonder how to reach and disconnect the stat cable, from above or from beneath??
Cheers
T
Old 05-23-2015, 07:42 PM
  #109
Model Year: 2005
used BMWhat App, or as it's now called Carly for BMW. recorded parameters and then used excel to create the graph.
Stat is possibly only accessible from underneath. I tried to disconnect the Stat from underneath on mine one day but didn't remove the right plate. I need another day now to put the car up and give it another shot.
Old 05-27-2015, 12:21 AM
  #110
Don dario's Avatar
Hi
Its very easy to take the small plate of near the front bumper. it take no more then 5 minute to unplug it:-) you dont even has to put the car up for this;-)
Looking forward to hear if Theres any changes!
Has any of you tried blocking the hose as mentioned above?
Regards
Quick Reply: 525i Engine/coolant temp low and little to no heat
