525i 2004 AHL issues
Old Jan 10, 2023 | 03:24 AM
Sinisterglitch's Avatar
My Ride: 525i E60 from 2004
Default 525i 2004 AHL issues
I am trying to fix a AHL issue on my 5 serie. The green LED near my light switch is blinking. I hope you can help me with this problem. I tried checking VIN numbers, coding to default, fuses, cables and many hours of google. Any help is appreciated. I respond quickly after i get a message.
I already replaced AHL module with same part number but still ghe same error. ISTA D went from red to grey as a module color afterwards.
Concern:
Are these two modules capable of AHL?
The modules
AHL = 6934122
LM = 6943288
the LM module has fault E519
the AHL module gives
Below is my INPA overview ( ignore MULF issue, that is another battle. Also no idea why my most modules have different VIN ).
Old Jan 10, 2023 | 06:38 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Whats blinking green? Why are you coding to default if you did not replace a module. Modules do not loose there coding. Your VIN is different in those modules because the previous owner retrofitted CCC and MMI.
Old Jan 10, 2023 | 06:52 AM
Thank you for the questions and awnsers. I updated the first post.
The green blinking LED is the one near the light switch when you turn it to auto/off/park/on. I coded the module to default in hoping it was some coding issue since this car had a lot of retrofits added before me.
I also added a replacement AHL module but that did not change the error i get in insta D.
Old Jan 10, 2023 | 07:32 AM
You are focusing on the wrong thing. The AHL is seeing the issue in the system and reporting it. Did you go through the test to see what the issue is. I would say 9/10 your issue is the SMC module under the headlight itself
Old Jan 10, 2023 | 08:27 AM
When i do the test on Ista and try to trigger the motors manually it states that there is not connection with the ALC
Old Jan 10, 2023 | 09:37 AM
If something was retrofitted on the light system and you factory coded it then you may have made it worse. Your issue are the SMC. Open up INPA and see if you can manually move the lights.
Old Jan 10, 2023 | 09:52 AM
I still have the old trc file so i can put the original coding back. I was looking in inpa on how to move the controllers yet it could not see the SMC controller.
INPA says "module does not respond" to LM_AHL, FLA and ALC. Only the LM function is available and no SMC option available.
Old Jan 10, 2023 | 12:29 PM
Update: issue is resolved ( not happy not knowing why i did not work )
I switched to a different partnumber AHL module ( 6934837 )
Old Jan 10, 2023 | 09:43 PM
donpb's Avatar
My Ride: '06 530i N52
So, the original module you replaced was also PN 6 934 122?
Old Jan 10, 2023 | 10:21 PM
I had a broken AHL with PN 6 934 122 and i found a replacement module with the same PN. Both gave the same error so i tried another AHL with PN 6 934 837. It worked instantly and no coding was needed.
I think the LM module was programmed to the AHL PN 6 934 837 and someone before me replaced that with the wrong PN. That has put me in the wrong direction.
Or both module PNs should work and coincidence that the first two modules were broken.
mohsennayyeri
Jul 8, 2022 09:05 PM
sparkyjonze
Apr 18, 2022 09:15 AM
khooger
Meet & Greet Discussion
42
Jun 14, 2009 05:09 AM
delje08
43
Jun 1, 2008 03:02 AM
Hopco
Jul 13, 2006 12:38 PM
