520i 04 Angel eyes - eyebrow not working
Old 06-22-2016, 07:49 AM
Wat4's Avatar
My Ride: 520i 04 2.2
Default 520i 04 Angel eyes - eyebrow not working
I recently removed old xenon lights and changed to LED rings instead.
Now the left eyebrow does not work at all. I have triplechecked all cables after installing and nothing seems out of place..
Tried googling, but no results for this problem. Anyone got some tips?
Size:  94.8 KBName:  eWn7hdj.png
Old 06-22-2016, 07:58 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
The eyebrow light has a separate conector to the cars wiring harness. The large conector controls headlights, turnsignals, adaptive lights. A smaller plug, 2 wires, controls the eyebrow. Did you get it plunged back in? Both of these connectors are located behind the light assembly.
Old 06-23-2016, 04:21 AM
Wat4's Avatar
These? They are pretty firm and don't seem loose. I will remove the headlight today and check it again. I'll update this post later.
Old 06-23-2016, 04:39 AM
Engine: M54 M10
No, when you had/have the light assembly out of the car, there are 2 wireing connectors to the cars wireing harness. The large connector, which handles all light functions, less the eyebrow and a second smaller connector, which is for the eyebrow only. Both connectors are located on the backside of the light assembly. I'm assuming you removed both headlight assemblies when you upgraded the angle eyes.
Old 06-23-2016, 02:44 PM
Wat4's Avatar
I swear I have no explanation for this.
Stopped at a gas station to fill up my tires. After that it suddently worked - I did not touch the wiring since I last posted.
It's in perfect condition now. Thank you for your help
Old 06-23-2016, 03:37 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
You're welcome. That was me that did that.
Old 06-23-2016, 04:59 PM
Engine: M54 M10
More power to the fix. Much better than a expensive, time consuming repair.
Old 06-24-2016, 11:48 PM
DanielFD's Avatar
My Ride: 2007 BMW 550i
This reminds me of a friend's e46 318i. the 8 and i had fallen off the rear badge. One day he woke up to go to work and found the somebody had perfectly installed his missing 8 and i.. Was that you too?
Old 06-25-2016, 06:03 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
yep! i totally remember doing that. i also left a dollar under his pillow, tell him he still owes me a tooth.
Old 06-26-2016, 11:39 PM
Wat4's Avatar
Do you mind fixing it again? It just stopped working.. you have a grudge against me now?
Quick Reply: 520i 04 Angel eyes - eyebrow not working
