520d - Does it have an airduct & airfilter for the turbo?!
Hi all,
I need some basic help, I'm looking to add a RPI scoop to my car (520d).
This is going to sound really stupid, but I don't think my car has air inlet for the turbo! - Logically speaking, this doesn't seem right since turbo's need air to work but in this case because its only a small unit maybe it doesn't?
If I look through the front grills, I can see the holes on the (left and right) side of the support beam, where air intake 'should' be, but mine are covered up! On the left side of the engine, I can see the (what I think is) air duct going towards the radiator on the left side. Another thing is there isn't an airfilter box like you have in the petrol engines.
I'm hoping that someone could clarify how the above points!
I'll try and get some pictures of the engine to show what I mean later today.
Thanks.
Thanks.
Originally Posted by russdx' post='912083' date='Jun 15 2009, 05:44 PM
i thought only the 525 and bigger had the turbos ?
Originally Posted by h2009' post='911891' date='Jun 15 2009, 03:48 AM
Hi all,
Thanks.
Thanks.
http://www.realoem.com/bmw/showparts.do?mo...hg=13&fg=20
Trevorken,
+1 Could you image driving a big heavy car like this if it didnt have a turbo.
Im sure its has a turbo, as there is the turbo hiss sound and I swear this thing wouldn't move without one!
Here are the pictures- and it looks like the RPI scoop will work fine. But what im still confused about it why there isnt an air-filter box?!
Edit: Thanks for that information! That helpful, but then what about dirty air, does the turbo just 'deal with it'?
Thanks.
Right now Im bored waiting for these pictures to upload over GPRS - only taken 25 minutes of my life!
Thanks.
Your turbo uses ambiant air, filted air and exhaust gases!! The turbocharger is bolted to the exhaust manifold of the engine. The exhaust from the cylinders spins the turbine, which works like a gas turbine engine. The turbine is connected by a shaft to the compressor, which is located between the air filter and the intake manifold, it draws air from your last picture!!
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Here it is.
http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=50
Originally Posted by Brit_in_NJ' post='912296' date='Jun 15 2009, 09:20 PM
So it is, now that was easier
