5 series auxiliary sound problem solved
The solution for the auxiliary cable connection and the bass sound quality is solved by interchanging the sub from left to right and right to left. Replace the sub under the driver's seat to the passenger seat and vice versa and magic happens. The bass and sound quality is solve. I did on my 525i 2006 car.
I first tried to replace the subs of my 525i with the subs of 328i and it did worked then I decided to tried something new such as replacing the subs from the passenger to the driver and it does work.
It doesn't. That makes no sense especially with the topology. Unless he switched r+. For l+. there is no issue unless ur using the BMW aux connector and/or forgot to plug ur subs back into the unit and/or did not hook aux up correctly.
My Ride: 08 528I Sport/Prem
DavaiLave
08-02-2022 02:16 AM
