My instrument cluster is not working after jump started my 2004 bmw 545i
Old 03-03-2018, 07:03 AM
muzamel7's Avatar
My Ride: 2004 bmw 545i
Default My instrument cluster is not working after jump started my 2004 bmw 545i
Old 03-04-2018, 09:43 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Try disconnecting the negative battery terminal for 1-1.5 hours. This, with any luck, will reset all of the modules, so when you reconnect the negative terminal, all modules will reboot and all will be good.
Old 03-04-2018, 10:15 AM
muzamel7's Avatar
i did for 30 minutes didnt work should i try again and wait 2 hours
Old 03-04-2018, 10:22 AM
Gee_115's Avatar
My Ride: 07 550i Sports Package
Originally Posted by muzamel7
i did for 30 minutes didn't work should i try again and wait 2 hours
If that doesn't work try disconnecting the instrument cluster for about 30 secs and then plug it in. It is not hard to remove just a few screws. Disconnect it only after you have disconnected the battery.
Old 03-04-2018, 12:05 PM
muzamel7's Avatar
ok i will try it and let u know what happens thank you
Old 03-06-2018, 01:16 PM
youngbmw's Avatar
My Ride: e60 520d lci
Model Year: 2010
have you plugged it in to a diagnostics machine/laptop and check all fuses. how was it jump started? and have you checked your battery health
Old 03-14-2018, 05:07 PM
muzamel7's Avatar
Hello i got a new cluster plugged it in and it worked and it now says passenger restraint malfunction and my idrive controller when i push down on it doesn't work
Old 03-14-2018, 05:14 PM
youngbmw's Avatar
Model Year: 2010
Hello i got a new cluster plugged it in and it wgorked and it now says passenger restraint malfunction and my idrive controller when i push down on it doesn't work
the restraint malfunction can usually be reset with a diagnostic machine
Old 03-14-2018, 05:41 PM
muzamel7's Avatar
what tool can i use to reset it
Old 03-15-2018, 04:21 AM
eugeneasaur's Avatar
My Ride: 530xi 6sp
all this from jump starting? did you clamp the positive lead directly onto your fuse box?
how does this happen...
Beemz530
02-28-2015 10:48 AM
djcentrino
06-24-2012 08:43 AM
miguex
10-21-2009 08:51 AM
r9ndy
08-25-2009 01:22 PM
JetBlack5OC
07-29-2007 08:17 AM
Quick Reply: My instrument cluster is not working after jump started my 2004 bmw 545i
