275/35/19 or 275/30/19?
My Ride: 2005 545i Dinan S Package
Im in the process of buying new tires for some 19inch oem 645i style 121 rims. They're going on my 05 545i sport. I read here, they will just mount with no problems. But I read at bimmerfest that 275/35's will rub, that I should go with 275/30's
Could someone confirm this? I'm about to pull the trigger on some Michelin PS2 and need to know before I do.
Thanks gents.
Thanks gents.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
245/35/19 and 275/30/19 are the recommended tire sizes for 19" wheels.
My Ride: 2005 530i Sport & Premium package with bluetooth, 6 disk cd-Changer, stock 18's dunlop wrapped, leather, adaptive headlights, CPO, See my gallery :DR.I.P...Stock Silver 2004 530i with grey interior, HID,
Model Year: 2005
Engine: M54
i've wondered this but havent really found the answer...
why use 245/35/19 in the front and 275/30/19 in the back... why not just use 35's for the front and back??.... or both 30's
orlee
orlee
It is recommend to keep the same rolling diameter as the stock tire sizes or stay within 3%. Anything above 3% can cause problems. 275/35/19 is greater than 3% of the stock rolling diameter. Tire Rack will tell you the same thing.
My Ride: 2004 545i carbon black / dakota black / sport package / 19' beyern wheels - 285 rear with 15mm offset
orlee
orlee
Originally Posted by B M What' post='569127' date='Apr 27 2008, 11:44 AM
I got 245/35/19 in the front and 285/30/19 at the rear. Iam not sure but I think they put 35's in the front to give the car a little more traction ? I also see these kind of setups on allot of sports cars.
Did you need to add a spacer to fit the 285/30 in the back?
My Ride: 05 545/6
orlee
orlee
class dismissed.
Originally Posted by fvicente' post='569136' date='Apr 27 2008, 11:55 AM
second number is a percentage, not an absolute #. ie the sidewall height is 35% of 245mm, or 245*.35=85.75mm. that's why the rear is a smaller percentage, since it's wider: 275*.30=82.5mm, a fraction smaller but not enough to trigger the ABS. 275*.35=96.25, considerably taller .
class dismissed.![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
class dismissed.
omszz
06-24-2009 12:08 PM
cartman503
20
07-31-2008 11:31 AM
