2010 BMW 535i coolant leak
My Ride: 530d msport Lci 2007
I would start with removing the hose from the tank and looking for cracks around the part that sticks out, then check the condition of the “o” ring inside the hose connector. Put some petroleum jelly on the hose connector and make sure it goes back all the way.
My Ride: 2010 535i
Drove it again last night and sat there for about 45 minutes after I parked and no leak. I woke up this morning and a larger puddle under my car. It seemed like one of the lower hoses leaked because coolant tank was almost empty. I am making an appointment to take it in. Hopefully it is nothing serious.
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Get under the car and remove the cover right under the water pump and thermostat (7 screws).
Wipe down the area and make it clean.
Run the car and see where its leaking coolant.
Your mechanic is going to do the same task.
You can do it and might find out all you need to do is tighten a few hose clamps.
