2008 Navigation DVD question...
My Ride: 2008 550i
I recently bought a 2008 550i. The seller did not have the navigation DVDs. I bought a set of the 2015 nav DVDs ($150) from ECS Tuning, so I know they are good.
The screen says "insert DVD." When I do, I hear the DVD player spinning, but there is no change to the screen. I tried an audio CD in the DVD player and it works fine.
So, is there a chance my car's CCC hasn't been updated to read the 2015 DVD? Do I need a 2008 DVD? Help!
Thanks
_______________
UPDATE: For posterity, the problem was the 2015 version of the DVD. It was not compatible with my 2008's system. I bought a used 2009 DVD, and it works perfectly. If I recall correctly, the 2011 version is the newest that will work in my car.
Thanks
_______________
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You're not putting it in the right slot if the CD is playing. You need to find your DVD player. It will say DVD on the player
My Ride: 2008 550i
Oh, I'm putting it in the DVD slot. No issue with that. What I was trying to convey is that to test the DVD player I put a music CD in the DVD player, and the DVD drive played the music just fine. Thanks though. I wish it was that easy!
Model Year: 05 530i
Engine: 3.0 M54
In that case, your DVD player is too outdated to read the newer DVD but it doesn't make sense because PN: 65902365699 (2015-1) is supposed to work if that's what you got.
My Ride: 2008 550i
My Ride: 2008 550i
My Ride: 2008 550i
That would be helpful for sure. I'm in the middle of nowhere. BMWs are few and far between. So, that's realistically not going to happen. I was hoping someone here could tell me how to check to see if my software version in the car is compatible with the DVDs I have.
Model Year: 05 530i
Engine: 3.0 M54
The DVD is the update. You could flash it since the DVD is not updating it but I don't see that helping since it will not read the DVD.
