2008 N47 E60/E61 Turbo replacement
My Ride: E61
Hi,
Hopefully someone can help.
I’ve just had the turbo go on my 2008 E61 N47 520d 76K. My first question is can anyone recommend a trusted reconditioning shop, I am in the UK?
My second question is the removal of the old turbo, I have looked at the Haynes manual and this states you have to remove the bottom bracing plate and lift the engine with a crane in order to remove the cat/dpf? This seems way OTT, does anyone having done this before have a rough procedure guide?
My Ride: E61
I have just finished this job. Ignore the haynes manual, this is an easy job 2 hrs in and out........
Air box out
Drain oil.
Undersheild off.
Turbo / intake and compressor pipes off and out the way.
Disconnect all relevant sensors.
Oil feed and return off.
Three manifold to turbo bolts.
Turbo bracket underneath.
Job done!
Air box out
Drain oil.
Undersheild off.
Job done!
chadillac2000
42
09-13-2017 11:15 AM
mikekilpatrick
03-06-2015 05:40 AM
