2008 550i w/Airbag light on
My Ride: 2008 550i w/M-Tech, Sport and Cold Weather Pkg
Anyone have any DIY advice for the code (i have the actual code written down somewhere) for the drivers active head restraint malfunction? I do not have a scanner so I cannot clear the code myself, last time it was cleared it was off for almost a full day before going back on. Just wanted to see if anyone has any little tricks I can try to get this fixed myself before going to my indy.
Thanks in advance!
Thanks in advance!
My Ride: 2004 BMW 545i sport package with Mteck & M5 Rims Mpower
There's no trick my friend no matter how many times you turn it off it will come back on . You will have to replace the module on the passenger side each . It should be under the sit . Racing it its the only way this will go away for sure .
code is 93F9 - Active Head Restraint Driver
@almandee26 - is it an airbag module? Or what is its exact name if you know please? It's under the passenger seat?
SFx550i
04-14-2015 05:00 PM
