2008 550i Rear Shock Mount Blow Out
Old Oct 4, 2025 | 10:45 AM
ZeroDfx's Avatar
My Ride: 2008 550i 6-spd; 2007 530i Sport
Default 2008 550i Rear Shock Mount Blow Out
I recently removed & replaced my OEM struts and shocks with Bilstein B4 Touring struts/shocks; I also changed out all the associated hardware like bump stops, dust sleeves, and mounts. I had already replaced all the control arms, tie-rods, sway-bar links, etc. several thousand miles ago. On a test drive immediately after the installation, I hit a bump in the road and the right rear shock blew right through the Lemforder shock mount into the trunk compartment.
I purchased all my parts from FCP Euro and they were great in immediately sending me replacement mount and shock while I had the defective ones removed, replaced, & returned back to FCP Euro.
Yesterday, after driving 1098 miles with the new replacement shock & Lemforder shock mount, IT BLEW OUT AGAIN!! For the second time the right rear shock blew through the mount into the trunk compartment (see attached photo).
I'm sure FCP Euro will be equally helpful again in exchanging the defective parts, but I don't understand why this is happening. I'd love to know if anyone else has had a similar experience or if you have any ideas about a root cause for this repeated breakdown.
Old Oct 26, 2025 | 03:39 AM
CVTBenhogan's Avatar
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron" SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR 2003 Audi A4 3.0 CVT "Part of the Moniker" Silver/Ebony, Prem, CW, Star 17s
are you sure you reused the shock washer from the stock setup. The bilstein instructions might omit the reuse of these.
Old Oct 27, 2025 | 07:54 AM
ZeroDfx's Avatar
I believe that is exactly what happened. Took it to a different shop who immediately detected the missing part that should have been saved from the old shock assembly.
wellison
Jan 16, 2017 02:09 PM
infernoz
Feb 17, 2015 01:43 AM
sotek
Apr 29, 2013 02:55 PM
06530-6M
Oct 21, 2009 10:05 PM
cleung
Mar 27, 2009 11:51 PM
