2008 535xi; p0335;p1727
My Ride: Alpine White 2010 535 M-Sport
According to the Bentley Repair Manual the codes are the following:
P0335 = Crankshaft Position Sensor "A" Circuit
P1727= Engin Speed Signal Plausibility
Additionally, the manual indicates that the 3rd # in each code represents the impacted system. The #3 in the 3rd spot indicates "Ignition system or misfire". The #2 in the 3rd spot indicates "fuel injection"
Im not an expert in e60s, but I would check out the High Pressure Fuel Pump as that is a common issue with e60s. Other than that Im lost. I hope this helps in the diagnosis.
