5Series.net - Forums
-   -   2008 535i misfire (https://5series.net/forums/e60-discussion-2/2008-535i-misfire-122930/)
Bmw08twin Apr 25, 2012 06:17 AM
I puchesed a 2008 535i with 65,000 miles about a month ago. it runs great some time has a ruff idle and misfired a couple times .
Had it at the dealer 3 time engine light comes on and goes back off . Dealer told me there is nothing wrong . Does anyone know anything about this ??? Somebody please help me with this thanks
Gene Apr 25, 2012 06:26 AM
search hpfp (high pressure fuel pump)
sounds like you might have a bad cylinder. is your dealer scanning for codes? have they ran a full diagnostic. had a similar issue myself with my 08 535i. dealer had to replace to cylinders
pukka Apr 25, 2012 07:51 AM
Did you mean cylinder sleeve (assuming these engines have them)? You can't replace a cylinder without replacing the entire engine block. Even replacing a cylinder sleeve would require major surgery. I had a similar situation and only had two injectors replaced to fix it.
NYAWE60 Apr 25, 2012 08:24 AM
At 65K if you didnt/dealer didnt replace these VERY SOON:
-spark plugs
-coils
-injectors
I'd say do the first two ASAP. If the problem isnt resolved then do the injectors. You should be able to acquire all of these parts for less than $1000. They're not difficult to install either. Anyone with some intermediate experience should be able to do it. Let us know.
Gene Apr 25, 2012 09:29 AM
sorry, pre coffee post...I meant injector, not cylinder...
baveagle Apr 25, 2012 11:03 AM
The MSD80 ECU in your 535i stores all kinds of detailed error information in its History even without the CEL on; cause of misfire, exact mileage when it happened, how often it happened, engine RPM, engine temp., coolant temp, engine load, actual speed, etc., etc. Go to another dealer or an indy to get the real story.
AchtungE60 Apr 25, 2012 11:48 AM
Hey sorry to hear. With the correct diagnosis software (not just a code reader) you can test each coil/plug and you can test each injector. The injectors are something I would definitely save for last. First Tell us what codes are being stored in INFORMATION MEMORY and then we can pinpoint these. If the car is a CPO there's nothing to worry about, let the dealer worry about it. It's pretty simple....
1) get codes
2) diagnose properly
3) fix
Bmw08twin Apr 27, 2012 02:04 AM
I'm not sure if the car had a tune up. That is something I will start with first. The only thing dealer told me is they ran a full scan one of the cylinders misfired a few times .
I don't have the proper scan setup what setup should I use ?? Was told there is a USB cable and program where could I get this what is it called ??? Thanks for all the help!
dgjk Apr 27, 2012 08:03 PM
Just went through this with my 08 535. Intermittent misfire with no lights on. The dealer was able to measure all the pressures and all of that stuff and was all normal. They recommended cleaning the valves by "walnut blasting" them. I bit the bullet and payed $500 for them to do it, and I was skeptical, but I have to say, after they did it, misfire gone, and she runs like a new car.
baveagle Apr 28, 2012 03:37 AM
What mileage is your car?
