2008 535i misfire
Old Apr 25, 2012 | 06:17 AM
Bmw08twin's Avatar
My Ride: 2008 535i black on black on black
I puchesed a 2008 535i with 65,000 miles about a month ago. it runs great some time has a ruff idle and misfired a couple times .
Had it at the dealer 3 time engine light comes on and goes back off . Dealer told me there is nothing wrong . Does anyone know anything about this ??? Somebody please help me with this thanks
Old Apr 25, 2012 | 06:26 AM
Gene's Avatar
search hpfp (high pressure fuel pump)
sounds like you might have a bad cylinder. is your dealer scanning for codes? have they ran a full diagnostic. had a similar issue myself with my 08 535i. dealer had to replace to cylinders
Old Apr 25, 2012 | 07:51 AM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
Did you mean cylinder sleeve (assuming these engines have them)? You can't replace a cylinder without replacing the entire engine block. Even replacing a cylinder sleeve would require major surgery. I had a similar situation and only had two injectors replaced to fix it.
Old Apr 25, 2012 | 08:24 AM
NYAWE60's Avatar
My Ride: 2008 535i, Sport, Premium, Navi, Comfort Access, USB/iPod Bluetooth, Cold Weather Package, Bi Xenon Cornering Headlights
At 65K if you didnt/dealer didnt replace these VERY SOON:
-spark plugs
-coils
-injectors
I'd say do the first two ASAP. If the problem isnt resolved then do the injectors. You should be able to acquire all of these parts for less than $1000. They're not difficult to install either. Anyone with some intermediate experience should be able to do it. Let us know.
Old Apr 25, 2012 | 09:29 AM
Gene's Avatar
sorry, pre coffee post...I meant injector, not cylinder...
Old Apr 25, 2012 | 11:03 AM
baveagle's Avatar
My Ride: 2008 535i2008 535i Monaco Blue PP, SP, SAT w/paddles, AS, CA, L7, NAV, PDC, Heated F Seats, SIRIUS, iPod+Aux, Bamboo Anthracite Wood Trim
The MSD80 ECU in your 535i stores all kinds of detailed error information in its History even without the CEL on; cause of misfire, exact mileage when it happened, how often it happened, engine RPM, engine temp., coolant temp, engine load, actual speed, etc., etc. Go to another dealer or an indy to get the real story.
Old Apr 25, 2012 | 11:48 AM
AchtungE60's Avatar
My Ride: E60 530i
Hey sorry to hear. With the correct diagnosis software (not just a code reader) you can test each coil/plug and you can test each injector. The injectors are something I would definitely save for last. First Tell us what codes are being stored in INFORMATION MEMORY and then we can pinpoint these. If the car is a CPO there's nothing to worry about, let the dealer worry about it. It's pretty simple....
1) get codes
2) diagnose properly
3) fix
Old Apr 27, 2012 | 02:04 AM
Bmw08twin's Avatar
I'm not sure if the car had a tune up. That is something I will start with first. The only thing dealer told me is they ran a full scan one of the cylinders misfired a few times .
I don't have the proper scan setup what setup should I use ?? Was told there is a USB cable and program where could I get this what is it called ??? Thanks for all the help!
Old Apr 27, 2012 | 08:03 PM
dgjk's Avatar
Just went through this with my 08 535. Intermittent misfire with no lights on. The dealer was able to measure all the pressures and all of that stuff and was all normal. They recommended cleaning the valves by "walnut blasting" them. I bit the bullet and payed $500 for them to do it, and I was skeptical, but I have to say, after they did it, misfire gone, and she runs like a new car.
Old Apr 28, 2012 | 03:37 AM
baveagle's Avatar
What mileage is your car?
